unconfigure ip-security dhcp-snooping information circuit-id vlan-information
unconfigure ip-security dhcp-snooping information circuit-id vlan-information [dynamic | {vlan} vlan_name |all]
Description
Unconfigures the VLAN info portion of the circuit ID of a VLAN.
Syntax Description
vlan_name Specifies the VLAN for which VLAN information of the circuit-ID is unconfigured.
all Specifies all VLANs.
dynamic Configuration options for dynamically created VLANs.
Default
The default is all.
Usage Guidelines
This command unconfigures the VLAN information portion of the circuit ID of a VLAN, restoring it to the default.
Dynamic VLAN option added in ExtremeXOS 30.2.
Platform Availability
